rebuild or replace Hydroboost module
- Replies 4
- Views 476
Tim Waldo 2 posts
Tractorman 2 posts
So a year ago (maybe 2) I had a line pop on the hydroboost/power steering system... doing a frantic search for the correct fluid SEVERAL forums suggested ATF+4 so that is what I bought and filled my reservoir with.... It felt right and I am pretty sure that is what I had used in the past.... NOW I have a leak between the hydroboost and the master cylinder... should I flush the system and add back the CORRECT power steering fluid OR should I buy a new hydroboost module? The books have not been helpful because the service manual I bought from Genos does NOT specify the correct power steering fluid... I'm not sure if it is because I was running ATF+4 or if it was just time for the gasket/seal was just time to go... so should I flush the system and prepare for replacing gaskets or should I flush the system in preparation of replacing the hydroboost?
