47re getting stuck in 2nd.........
- Replies 5
- Views 4.7k
Wild and Free 2 posts
bronzebeard9 2 posts
white01 1 post
My truck sat for about three months before I got it rolling again, now that I have it up and runnin, my tranny intermittently decides to stop shifting through the gears, it will lock in second and not want to shift through. If I drop in neutral and then put it back in drive it seems to take care of it for at least a little while. the fluid and filter have about 3,700mi on it but the bands have never been adjusted (a auto trany guru I am not) its been in the low teens to the negative single digits and the truck has not been up to full operating temp since I got it running (I still have to put a high temp thermostat in it and get a winter front on it) not sure if the cold weather and sitting for a long period of time coupled with the fact that it hasn't had a lot of drive time on it and hasn't been thoroughly warmed up and put through its paces would effect the proper function of the tranny, any thoughts would be much appreciated, thanks guys!!
i take it back, it sticks in 1st and 2nd, putting it in neutral and then dropping it back in gear is still "unsticking" the trany but is getting frustrating.....
fluid level is good, fluid still seems to have good lubricity, i used the proper type of trany fluid and a few months ago before i parked it i didn't have ANY problems with the thing (i HATE auto transmissions) next step, i'm changing the fluid, if that has no affect i'm adding a stop slip fluid modifier (against OEM standards for a 47RE) and hope it buys me enough time to get my 5 speed shipped to Alaska, i have a 12v duelly in Washington that got flooded a few years ago, but it was a good price…..$FREE.99
