transmission shift problem
- Replies 4
- Views 2.4k
Wild and Free 2 posts
balsip 1 post
fire176969 1 post
i have o2 3500 47re was working great no problems was hooking to my trailer, looked and need to move just a little, pulled up, and then it would not shift back to revears. binds up shifter, idicator came back to drive but no farther, i unhooked sheft lever at transmission, shifter went freely back to park so i could turn key off, at first i could shift low second and drive by hand at the trans. that is as far as it would go. after i shifted it a couple of times. and tryed a little harder to see if it would jump past whatever was holding, it,. now lever moves freely, anyone know what i might find when i drop the pan, is their any common shift parts that fail inside, any help app.
