transfer pump switch over
I'm replacing my transfer pump the one on the truck is not the original one,I bought a FASS DDRP 02.The suction is a different style fitting,it seems like a stainless tubing with a quick connect,did anybody ever experience that,to adapt the FASS pump I need to cut the stainless pipe and adapt some kind of a fitting ,in my package they sent me 2 banjo fittings /filter/rubber hose.Not sure what pump they had in there,the suction tubing must have been replaced that quick coupler seems like a good set up,it would be a waste to remove it.:duh:How can I attach pics to my thread
  • Replies 22
  • Views 6.1k
glowshift offers a fuel pressure gauge that as a range from 10 to 102 psi for my truck the range is a little too high,my manual gauge shows idling 20 psi and average running pressure 16 psi,usually a gauge is at it's best accuracy at 75% .The gauge should be in the range 0-30 psi,I think I'll shop somewhere else.
they have that as well, perhaps not in the color set you were looking at but the gauge i bought from them is 0 - 30 psi fyi
Right on,I'll go back on the site to see what they have
