Rear Main Question
Ok guys bear with me, I did a search on changing rear main and no luck anywhere, I know I have seen it before but cant remember. If I remember right you can replace the rear main with oil pan on or off right? Right now my eng stand has the back of my block hid so I cant see it.I need to pull my oil pan before I install eng. to clear cross member. I just wanted to do everthing I can while eng is on stand. And trying to plan it all out. getting close:hyper:
  • Replies 2
  • Views 1.9k
Thanks, I knew I saw it somewhere
