- Replies 6
- Views 2.3k
DieselDave 3 posts
thracing 1 post
JOHNFAK 1 post
stodg73 1 post
So I am planning on doing a little work to my truck and I am looking for input if I forgot something, or have a half-baked idea. :cookoo:I have a 4" exhaust brake and I am looking to upgrade my stock truck with the following:- Super B twin turbo- Exhaust manifold- 5" Exhaust with the brake on it- 150 CPP injectors- I think I am going to go with an edge chip, not sure about the quad- Propane injection- Head studs- Southbend clutch- Upgraded lift pumpNow my first goal will be to get the turbos on, my old turbo is not long for the world (lots of play and oil is leaking from it). I should be fairly straight forward, off with the old on with the new.Parts needed:- Head studs- Exhaust- Turbos- Exhaust manifoldMy second goal is pulling the transmission and transfer case. The fluid is a bit dark in the transmission, so I am going to drain and replace it. The seal is toast in the transfer case, and I think the yolk may be as well. Its getting a fluid change too. The gasket between the two has a minor weep, so I plan on replacing it as well.Parts needed:- Gasket between tranny/transfer case- Southbend clutch- Replacement seal/yolk- What types of oils?My third goal is to get the engine to quit leaking so much oil. I tightened the oil pan bolts to slow the weep down there, but there still seems to quite a bit leaking between the tranny and engine. I am not sure why.- Oil pan gasketSo far, is there anything I missed?Thanks for any input
