High Idle Fooler
Ok it’s getting to be that time of the year again (COLD) and It won't be long before it's snowing and blowing. So…………. can someone fill me in. Apparently Prowelder has 2 versions of the High Idle Fooler. The Original High Idle Fooler and now the High Idle/MPG Fooler. What’s the difference?
  • Replies 2
  • Views 3.1k
Ok... standard version as you already know is the high idle with 3 or 6 cylinders... http://mopar.mopar1973man.com/cummins/2ndgen24v/high-idle/high-idle.htm MPG fooler is here... http://mopar.mopar1973man.com/cummins/2ndgen24v/mpg-fooler/mpg-fooler.htm Prowelder is the guy to talk to for getting the assembled version...:smart:
Thanks, I guess I'll have to check it out.
