AC Squeak = bearing?
- Replies 4
- Views 2.1k
IBMobile 2 posts
Junkman 1 post
MarbleCrusher 1 post
My air conditioning compressor recently started squeaking only while the compressor is engaged. Turn AC off & no squeak. I'm thinking bearing but haven't found a diagram to know that the bearing can be changed. The clutch is working. The only issue is the squeak & potential failure.I recently did the heater core and the AC is cold. Coolant is new, filled and not leaking. The less I have to disturb the radiator or AC the better. The usual "I want to be down as little as possible" applies. So...Can the bearing be replaced? Can it be replaced without removing the compressor? Does the radiator have to come out? Is the bearing a Dodge only part or is the bearing a standard size? We have a bearing supply house & I could order from there if only the bearing needs to be changed.It looks like bearing would be pressed into the pulley (P1 #3) of the pdf. In which case, I may be able to press out & simply replace. Comments?
AC_Clutch.pdf
