Another Track Bar Question
- Replies 9
- Views 3.1k
dually 2 posts
ddossdd 2 posts
MarbleCrusher 2 posts
cummins2k 1 post
New to the forum, been doing a lot of reading since I bought a dead 98.5 cab chassis with an 11 foot service bed. Got her running soon enough and have most of the bugs worked out of her but I am troubled by a wobble - shimmy at about 64 to 68 MPH. Have replaced most all front end components (ball joints steering box - way bad, and a couple of the steering link joints link joints) as well as the the track bar twice. It is from Autozone. The first one I threw on a few weeks ago and didn't think anymore about it, had other know bad parts to replace. All said and done everything I've found to be bad has been replaced, some obvious, some checked with a dial indicator and jig. So.... this shimmy - wobble will not go away, got back in under the truck again to see the track bar moving vertically in the ball stud, more than obvious, 1/4" or more. Pull the track bar out, feels tight, but taking a set of channel locks an pressing down on the ball stud it appears to be spring loaded. Sent my boy off to get another one, he brings me back one that appears to spring loaded also, not as much available compression though, maybe 1/8" or a little more. My question to the forum is: Am i wrong in thinking that this ball joint should in no way, shape, or form, have any play what so ever or am I missing something?
Thanks, I'll update my sig now.
Toe, 1.5*
Caster 3.5*,3.4*
Thinking might be control arm bushings, look good, no slop while prying? Thoughts?
Whoops, .15* toe, not 1.5* WOW!
