- Replies 4
- Views 2k
Mopar1973Man 2 posts
ISX 2 posts
Alright I got shims from work using their punch die set thing and did some other things like put in new copper washers and banjo bolt washers on everything. Upped the pop pressure from 220 to 280 (stock is 260). Well now it runs like crap. It just sits there and chugs. I have good fuel pressure and no fuel leaks. So the real question is, do I actually need holes in those shims? I'm thinking the fuel is getting past the edges of the shims and allowing it to run, barely, but don't know if it works like that or not.
A video to entertain the masses. Think I might go ahead and take the shims out and see what happens. I didn't touch the injection pump so it couldn't be the culprit.
http-~~-//www.youtube.com/watch?v=pB6EqzZq6tA
Well I got impatient and just took them back apart. I need this truck in the morning. Anyhow, the myth has been busted.The return goes up through the center straight through the spring and everything. The OEM shim was facing the nozzle and the other shims were on top of it so you can see the intense pressure trying to push it's way out of the injector return line. Little more and it woulda put the holes in the shims for me lol. So why did it run rough! Return lines relieve excess fuel that is under pop pressure, so what exactly does that mean? What exactly is it's purpose..
