ABS light and parking brake light staying on
- Replies 5
- Views 2.4k
dripley 2 posts
walsey 2 posts
Wild and Free 1 post
Boy, the last few days I ain't had much luck. AC goes out and now the ABS and parking brake lights are staying on. I checked for codes and got nothing and checked the fuses everything looks good there. The truck brakes just as it always has since I got the truck. The speedo and everything in the gauge cluster are working properly just the two lights are on. I know it could be several things but just wondering what order I needed to go in to fix this problem. From my searches on here I think it may be the two speed sensor up front. Would you replace them first and then if that didn't work replace the sensor in the back? If not that check the ABS motor/computer? Either route Im going to check the wiring and button up any problem areas I might have. Thanks in advance
