Cruise control
My cruise control doesn't work. The light on the dash comes on but nothing happens when you push set. I've replaced a few rotted vacuum connections. Where is the actual cruise control unit located? I have a 2001 2500 with automatic trans.
  • Replies 2
  • Views 1.9k
The servo is under the drivers side battery. From what I have seen the servo takes a beating from the battery above it. corrosion that is.
