putting exhaust brake on stock 2004.5 48re
I've searched the transmission threads and couldn't find out what would be involved putting a PacBrake or similar exhaust brake on my stock 48re. My combined gross weight is 17.5k and so interstates are no problem but on secondary roads where you can have 10% and higher grades I could use more stopping power.
  • Replies 5
  • Views 2k
Ive been looking into this for my 04. Ive looked into all BD products so im going to use their names. You would need the exhaust brake, a transmission controller (towloc), and I would get the valve body so that your holding pressure would be higher. :2cents:
I would go with a PXRB from pac brake. I would also consider mild trans upgrades to hold the retarding power. Anyway you go you will need a controller to lock the torque converter. I personally don't like the way BD regulates pressure, looks too easy to plug and fail which would push too much back-pressure to the head.
JohnWhat kind of transmission upgrades would you make?
That's a question I would ask a good trans builder, but I would assume a torque converter and valve body???
