- Replies 2
- Views 1.3k
flagmanruss 1 post
JAG1 1 post
Out on the farms I've worked on occasionally, we have needed some custom bends in our plastic PVC conduit. We found that about 10-12 slow turns of the pipe at the hot exhaust will not burn and make it soft enough to bend. Saves buying a 200 dollar conduit heat bender anyhow.Tip.... if you see the pvc turn color like it's burning, you need to turn it a bit faster
