July 25, 201213 yr Has anybody experience this electrical problem,both went down at same time,check fuses and both are good??
July 25, 201213 yr There is a fuse called IOD which is the culprit.. It is the one with the fuse puller thing on it. I think it stands for ignition off disconnect which pulls the plug on everything that draws power to allow for long term storage without the battery being drawn down. But it also gives power to the radio and dome lights and stuff..
July 26, 201213 yr Yes thats the one, i pulled it while repairing my maplight harness. kills interior.
July 27, 201213 yr Mine went out day before yesterday and couldn't figure it out. How do you get the black cover off that is over the fuse.
