Need help I.O.D. fuse blown
I think I have the same problem that wagntagn has a couple post below. I think my I.O.D. fuse is blown but I can't figure out how to get the plastic protector off the fuse to replace it.
- - - Updated - - -
Nevermind. I finally got that booger off. Problem fixed.
  • Replies 3
  • Views 2.3k
That plastic clip was designed so the dealers could store the vehicle for a long time without losing the batteries on the truck from Ignition Off Draw devices.
What's the trick to pull the fuse out ?
BFI ( brute force and Ignorance). Use a pair of long nose pliers ..squeeze and pull out. Discard the plastic keeper.....it really isn't needed - or, "pop" the top piece off so that you retain the appearance of the frame (fast identification of the IOD) ...but you can pull the fuse through the top.
