ISX: first question!
- Replies 12
- Views 3k
rancherman 6 posts
ISX 5 posts
Mopar1973Man 1 post
Ok, you probably are aware of my project: putting a '97 cummins+6spd(2002) into my 'ultimate ranch vechicle'Which is my '94 2500. (the one I snagged in Wyoming)Very interested in using you 'ultimate' P7100 mods, but I'm curious on it's total driveability. I'm not the only one to use this truck when completed.. Wife will jockey it too! I just got her used to NOT USING THE ACCCELERATOR when starting from a dead stop.. (actually relying on the built-in torque of the stock cummins) Our experience is based on our '00 cummins with 6 speed.what does your recommendations on the P7100 do for 'out of the hole'? Will it react similar to the stock vp44, or will a little right-foot-work be needed to 'start-rolling'?I'll probably get the truck together 'stock'.... and make sure everything is working properly, before doing any mods.
