Looking for Staff Members
After install of the insight I set the guages to read boost and frp. the highest the boost got when getting on it was 27.8 and 1.9 crusing. the fuel rail pressure at idle reads 5.5kpsi and and will hit around 20 kpsi when on it and crusing sits about 7 to 9 kpsi. Do these numbers sound right??
  • Replies 7
  • Views 2.3k
Those numbers sound ok. My 06 runs close to the same numbers, I'll check on my way to the office in a little bit.Sent from my DROID RAZR using Tapatalk 2
Hey Jim at idle rail pressure runs about 6.8 and boost is at 2[ATTACH]4876[/ATTACH]And at wot running around 90mph rail pressure runs about 24.7 and boost is 38.[ATTACH]4877[/ATTACH]I'm running my programmer in the mild setting. Sent from my DROID RAZR using Tapatalk 2
Jason where you in a hurry lol 90mph I will see what mine runs at with a programmer when I get my jr. I would think it would make a differance. I appriciate the info bro.
Depends on who you ask! Lol Actually it seems a lot lately that I am always in a hurry. I was trying to get the numbers at wot and it just so happened to be doing 90:eek:Sent from my DROID RAZR using Tapatalk 2
The 03-04 and 04.5-07 will read different pressures and boost readings as they are setup different in terms of rail pressure maps and turbo/wastegates. I would say your reading correctly.
Cool Thanks AH64ID. Just installed the Smarty jr so will see how it works out.
