Couple questions about boost and injectors.
- Replies 7
- Views 2.3k
98whitelightnin 2 posts
jfrye 2 posts
paul99 1 post
pepe 1 post
I have a 99 quad cab dually, with 5 speed tranny and 3.55 gears. It is basically all stock except for the AirDog II 150. I have Fuel PSI, Boost, and EGT gauges. I currently only see 16 PSI max boost. Is this normal for a stock truck? I have tried searching on the forums, and all I really saw is max numbers of what the turbos and engine can produce and handle. So, can I raise my boost numbers closer to 25 without a boost fooler? Its really not a big deal to me, seeing as how the truck seems to run great, but just curious. Basically, just curious about what I would need to achieve 25 PSI.I was also considering getting some RV275's. Will I notice any gains adding these right now, or do I need a programmer to notice the gains? At this time, I wouldnt be able to afford both, so I would rather not get injectors I cant use until I get the programmer. If a programmer is needed to notice the difference, what would be the best programmer to get? This truck gets drove an average of 10-12 times a month, usually pulling a 7x12 trailer. With the flatbed on it, and such an air gap to the front of the trailer, it sucks the MPGs down.One more questions is about Mike's MPG Fooler. I am not all that great with the wiring, but it looks like you have to tap the IAT and ECT sensors? Is the High Idle Mod required for the MPG Fooler? (<- may be dumb questions, but I dont really understand these) I obviously wont be doing any of the wiring for these, but just some questions for when I have a buddy do the wiring.Thanks in advance for the help,Justin
