01' will not start, no power to lights, batteries charged
My 2001 will not start, starter wont click, lights will not even come on. Batteries have a sufficient charge but everything electronic seems to be completely dead. I dont even get the clicking when you open the door and the batteries are in need of a charge. Installed a new alternator last month and my Optimas are in great shape. I disconnected both negative terminals to see if anything would reset but it did not do anything. Started great and ran fine last night...:banghead: I know it is in need of a bath really bad and I have been driving through a heck of a mud hole getting to and from work...perhaps something came loose??? Any help is appreciated!
- - - Updated - - -
Well, guess I should have checked all of the wires before posting. Ended up being the positive cable running to the fuse box that pulled out of the terminal. :duh:
  • Replies 1
  • Views 1.8k
Popular Days
Did you try the 140 amp fuse in box under hood? Also is your neutral safety switch on clutch ok?Guess I should finish reading before posting.
