- Replies 8
- Views 3.3k
klcammie 2 posts
diesel4life 2 posts
rickf 1 post
Ironforger 1 post
i will be installing my first lift pump friday ,it on a used 2002 2500 4x4 dodge(duh) 59k miles .anyone have any advice on items not covered in the instructions ? my stock pump has 11 psi at idle and since i have seen all the horror stories in the forums i decided to fork out some cash and do it. is the line from the pump to the fuel filter larger than stock , if so should the line from the filter to the vp44 be increased also ? thanks for any advice
