- Replies 3
- Views 1.5k
flagmanruss 1 post
dripley 1 post
els1958 1 post
After my heater core, evaporator, and dash cap install, the blend door would not work. It's stuck in the cooling position. I assumed it was a broken plastic piece at the bottom of the shaft, so I ordered a heatertreater part. Well, the plastic piece is fine. The door is unmovable. The blend door shaft is in position at top and bottom of hvac box - i can see that much. Anyway to rectify this without pulling out the hvac box again. It cost me $70 to have AC recharged and I'd like avoid that.Thanks,Eric
