Converter lock and pipe flange
I have searched the forums til I am blue in the fingers and I cannot find a diagram for the lock out switch. I know I am terrible at finding the right search terms but man! I thought I saw diagram a while ago with the switch and the included resister? I am not an electronics person, I know it is a 33 ohm resistor but what about the rest of the values? volts? watts? And would you know where I can find a flared section of pipe for the 4" outlet on a Banks brake? Or some other way of adapting the pipe to it?
Rick
- - - Updated - - -
OK, Let me rephrase this. I am looking for the diagram for the manual lock up switch. My original post may have been confusing. I know some of you have this.
he pipe would be a bonus but if I do not find one by this weekend I will make one.
  • Replies 3
  • Views 1.8k
I have that diagram but I am looking for the one with the resistor to prevent the check engine light, or just the values for the resistor. Hex0rz, I am in need of the down pipe from the turbo outlet which in this case is the Banks Brake and is a 4" flange joint.
