a buddy of mine swears straight veggie is perfectly fine to run through the p pump. i had problems with it on my idi with the stanadyne db2 pump , pumps would go bad after a few months. i was just wanting to stir the pot a bit and see what you guys thoughts are.
  • Replies 8
  • Views 3.4k
i have also heard that from a bunch of people...but of coarse that's after i bought the 99....i think even a TV show said if you wanted to run SVO than get a ppumped cummins(well they said dodge...)
looking at the fsm, it appears that the p-7100 pump is oiled from the engine lubricating oil supply. if that is in fact the case the p pump would be far superior in the lubricity dept. im reading alot these days!
Ok... I would consider the weather conditions and fuels... Being Veggie Oil will gel quickier I would be careful in cold country. The other factor is that Veggie Oil mixed in Diesel will seperate and settle to the bottom of the fuel in a gelled state. (Like bacon grease) The other problem is that Veggie oil in thicken state will cause strain on the injection pump. Then also might cause issues with injectors spraying the thicken fuel. (Poor performance) Just a few tidbit I heard about...:2cents:
with the idi and the stanadyne db2 i have a valve that switches back and forth. i am using a wrap around filter heater and im using the built in tranny cooler in my rad as a heat exchanger. it keeps the oil at 140 deg. at the ip no problem as long as its up to operating temp. the only problem i had was the ip's only last a year at best. that and when i switch to veggie it mixes the little bit of return diesel into the veggie tank and vice versa when switched back. what i need to do is do a dual filter head setup and switch from the filter heads right at the ip. and rig up a timed return setup to catch the mixture before switching the return. its complicated but it works. i usually just had to drain the tanks and flush them out every couple of months. well worth it when i get wvo free. temp isnt too bad here in fla. if i was up north i woud want to get an in tank heat exchanger/electric heater for sure. we rarely freeze down here.
Ummm... Well you might not in Florida... But here in Idaho its... Ummm... 25*F and falling might get down to about 10*F tonight... :thud:
i see idaho tries to lure you in with good taterz and then tries to freeze the taters off ya. i am such a puss now. it was like 59 today and i was bitchin' cuz it was cold. :lmao2:
that was our hi for the WEEK here in the OK
  • 4 months later...
http://www.oilcrusher.5u.com/ I replied on a previous thread and was not sure I could find the link but I did, above. This farmer has done his homework AND has empirical data to back it up! After reading this guy's info I would never recommend WVO or SVO to anyone. And I understand the problems with Biodiesel as well. The problem with almost ALL Biodiesel is that they also use WVO - what % - who knows!? Yes, I know they process it but this guy has tested Biodiesel and has found SALT in ALL of it! Salt + heat + close tolerance = big, expensive trouble! Salt can come from fried foods AND animal fat. Yes, you may be OK if you do not tow or haul taxing and heating up your engine... but if you do?! Look out! He has some case examples. I highly recommend reading this guys research!
