No tail lights
I have no tail lights, dash lights, marker lights. Only my headlights are working .The fuse blows after 1 minute I turn the lights on. Some advice ,where to start to check
  • Replies 7
  • Views 4.4k
Unplug everthing that is blowing and see if the fuse blows again then if it doesnt plug one thing at a time and see when it blows. Let me know the fuse and when i get home in 7 hours i will study a wiring diagram
- - - Updated - - -
Also pull your headlamp switch and inspect the wiring
Lower your spare tire down and see if the harness chaffed somewhere up between the tire and frame. Happened to mine a while back and thats what it was. Soon as the bare touched the metal pop goes the fusey :lmao:
Well, there pretty much has to be a short somewhere, unless you've wired something else to this fuse that should not be. I don't know how to isolate the systems which are wired to this fuse. It helps to be logical / systematic. Check the trailer plug for damage... check each rear light for damage & the harness to them. It would probably be chafe damage to chaise ground. It could also be damage to the front marker / parking lts. Consider the possibility of prior accident damage that might have stressed the wiring. I'm also seeing reports of light sockets & trailer plugs corroding so as to cause grounding issues, so look inside.
I think found the short, my side maker lights on the dually fender on the left side . lights are working now for 2weeks.
