- Replies 3
- Views 2.5k
Mopar1973Man 1 post
bjytech 1 post
rdsutton 1 post
Truck in sig has a slight (mili sec) cut out, pause, on sllloooww deceleration when manually manipulating the throttle cable. Just noticed it today. I was slowly revving engine, listening for a ex manifold leak and noticed when I reved engine up tp 1500rpm then very slowly let the throttle return to idle there was a dead spot round 1200rpm. Could not duplicate it going fast, or while driving. Any Clue, should I be concerned? Yes I do have a pin hole ex manifold leak on #3. Only audible @ idle and visible by the blowby between head and manifold...
Up date,,, no codes and TPS 1yr old and tested good. Sprayed linkage.Still have the dead spot!! I have crawled all over that engine the last 2yr & never noticed it. I believe the throttle/injector pump problem is new one on me.. In the past yr I replaced ALL fuel Lines & oversized banjo fittings from tank to pump.
Edited by rdsutton
