Slow building fuel pressure
- Replies 3
- Views 2.2k
mopartechnician 2 posts
Ilikeoldfords 1 post
So I decided it was time to install ball valves to make filter changing on my airdog easier. While I was doing this I changed the fuel filters out and pulled the regulator apart so I could inspect the ball and spring. Well now the pressure slowly builds and it takes a good 25 seconds before the pressure hits 18psi. Im at a total loss. This is verified by two mechanical gauges. Pickup starts perfect. Its an Airdog 2-165. The regulator is different than the spring and ball. It has a spring that pushes on a plunger type metal piece to regulate
Edited by mopartechnician
