I just bought this truck and want to drain trans fluid, what fluid does it take?
  • Replies 3
  • Views 2k
ATF+4
CAPACITIES   (Be careful with initial fill and total fill of tranny)
Engine, with filter..........7 quarts [1]
Cooling System, Initial Fill..........18.7 quarts
Automatic Transmission, 48RE Initial Fill..........4 quarts
Automatic Transmission, 545RFE RWD Initial Fill..........5.5 quarts
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts
Automatic Transmission, Total Fill
   5 speed 545RFE RWD..........16.9 quarts
   5 speed 545RFE 4WD..........16.9 quarts
   4 speed 48RE..........16.9 quarts
Manual Transmission, NV3500 RWD..........4.9 pints
Manual Transmission, NV3500 4WD..........4.2 pints
Manual Transmission, NV4500..........8 pints
Manual Transmission, NV5600..........9.5 pints
Differential, C205F Front..........3.4 pints
Differential, With 10.50 RingGear AA Rear..........4.6 pints [2]
Differential, With 11.5 RingGear AA Rear..........7.6 pints [3]
Differential, With 9.25 RingGear LSD Rear..........4.9 pints [3]
Differential, 9.25 AA Front..........4.9 pints
Differential, With 9.25 RingGear STD Rear..........4.9 pints [3]
Transfer Case, NV271..........4 pints
Transfer Case, NV273..........4 pints
Transfer Case, NV241 GENII..........3.4 pints
Transfer Case, NV243..........3.4 pints
Transfer Case, NV244 GENII..........3.4 pints
TORQUE VALUES
 Oil Drain Plug.....25 ft/lbs
   Manual Transmission NV3500
     Fill Plug 14-20 ft/lbs
     Drain Plug 14-20 ft/lbs
   Manual Transmission NV5600 6-SPD
     Fill Plug 22 ft/lbs
     Drain Plug 30 ft/lbs
   Manual Transmission NV4500
     Fill Plug 25-35 ft/lbs
     Drain Plug 25-35 ft/lbs
   Transfer Case
     Fill Plug 15-25 ft/lbs
     Drain Plug 15-25 ft/lbs
If its 4wd do you t-case while you are there. Its only a couple more qts. Also replace a qt of atf in the trans with lucas trans fix. Its will help the bands and clutches
Lucas trans fix, ok will do. You know back when it was cold it wouldn't shift into high when below 50. Had to pull over set there for 20 seconds and take off and it would shift just fine the rest of the day.
