Wiring LED light bars into existing consol
- Replies 9
- Views 4.5k
MnTom 3 posts
mopartechnician 3 posts
Ilikeoldfords 2 posts
Tomassend 1 post
I have a 2006 And recently purchased LED light bars which I would like to mount on the front of the vehicle.
I will be replacing the two lower stock fog lights with LED pods and adding a 20 inch lightbar under the grill between bumper to use for highbeams.
Ideally I would like to utilize the fog light function for the LED pods but leave the pods on when initiating the highbeams.
Speaking of the high beams I was hoping to incorporate the 20 inch lightbar into the highbeam switch that's located on the steering column, does anybody see any issues with doing this?
To summarize I suppose the total level of effort would be integrating the pods into the current fog light switch and then bypassing the fog light off function when initiating the highbeams; leaving all lights on. As well as including the 20 inch bar to turn on with the highbeams.
Any insights you guys had out there are greatly appreciated hope everybody has a great Memorial Day weekend.
Edited by Tomassend
