I recently inspected my ball joints & they are toast. All the boots are torn/missing, the lowers have about 1/4" play, and the uppers aren't far behind. Not sure if they are OEM, but all the aftermarket ball joints I have seen come with a zerk fitting & these are sealed units (190K on the truck). I can't afford to pay a shop to do the job so I plan to do it myself. I have a fair ammount of experience in auto repair, replaced ball joints on smaller vehicles, and have some front end experience with this truck; had to replace the front rotors/hubs when I bought the truck - yea, those 100lb cast iron lumps! I'm pretty well tooled-up (jacks & stands, air tools, 3/4" drive socket set, etc) but what concerns me is getting the old ball joints out. My truck came from up-state NY so there is no shortage of rust on the suspension. I'm planning to borrow a removal tool set from Advance or Auto-Zone, hoping it will have enough oats to do the job. I've always had a tussle trying to unseat the tapered shanks of tie rod ends & ball joints out of steering knuckles using a pickle fork. Guess what I'm looking for is any tips, lessons learned, been there-done that-got the knuckles to prove it type of advice before I dive in.
I was looking on RockAuto and it seems that Moog (Problem Solver) & Raybestos are the two premium replacements, but their design varies significantly. The Moog use what they call a "gusher bushing" which is a metal insert to support the ball with slots to allow uniform flow of grease. The Raybestos use a graphite-impregnated polimer insert to support the ball. Each say their design is better than the others' - open to opinions.
I realize that most folks here talk about their 4WD ball joint battles. If there is interest, I can take pics & do a write-up.
Thanks in advance for your interest & help!
Joe in St Louis
