Can't believe I did this
Drove my truck off the end of my drive way, got it stuck and got out to see what I could do. It just cut off and will not start. It did loose a little oil from a cooler line. Any ideas? Is there a extreme angle cut off? post-2376-0-32060200-1410230171_thumb.jp
  • Replies 22
  • Views 5.5k
good to hear man!
Ya know,  I was thinking back  about  some of the hard landings  I've been through over the years..      Check your battery holdowns!     Those  dudes  can be  the most overworked   device...     especially   when  corroded  halfway through.      Having  a  battery  hanging/shorting out against something  causing a fire  isn't cool..
I've had  gassers    smack  pretty hard   which   jarred  battery cable loose...  which   killed the motor..
Hey Santan,
How did your truck survive this? Any problems?
Dave
