cab corner replacement
Hey guys, It's been close to 25 years since I've done any 'at home' body work. I was wondering if anyone has replaced their cab corners.. and found a good product to use, or one to stay away from? Several choices on ebay, about 35 to 50 bucks a corner. I'm going to replace the corners, get it waterproof again, and then box line the whole cab from the lower body line down.. Thinking dark grey on the maroon should look pretty good? Now that the box is off, changing up the corners will be lots easier!
  • Replies 8
  • Views 4.5k
I'm actually in the middle of replacing my rockers and corners right now. My parts came from mills supply, they're made in Taiwan (good luck finding parts that aren't) but seem to fit/weld nicely. Get a good spot weld cutter and it will make your life a lot easier. Some careful measuring, a little patience and a 12 pack and it actually went pretty well.
On my brother in laws s10 I just filled the rust holes in the cab corners with expandable foam and shaved it down after it set up and he painted right over it...................redneck style. :thumb1:
:rolleyes:    sounds about  par  for  a  S-10..
I'd  bet  it's  still looks  good though!
I was going to use a body foam for my rust holes and the spray the rockers with bed liner. Should keep water and air away from the metal which means no rust
How  would  that foam work on a brand new truck..  the ultimate  preventer?     Rockers,  cab corners, heels of the fenders,   heck even the  bottom inside of the door
I know it'd be  a total  bugger  if  you ever needed to do  body work afterward...  but  we never crash do we??
I wouldn't say it looks good but definitely better than the gaping holes in the rear corners and it helps keep the critters out.
hmmmm,   just  watched a vid on  using   a   panel bond  adhesive!     This  may be just the ticket..  no flanging, welding, (or very little)..
This was on my 01. It was an omaha pickup so the rockers, cab corner, and rear fenders were rusted and had holes from all the salt
Shouldnt have to worry about it on my 06 since they dont use salt out here. But I might line the rockers for chips. Buddy dif it on his 01 and it looks awesome
Edited by mopartechnician
