Compressor Wheel Upgrade
- Replies 5
- Views 4.4k
mulcher812 2 posts
CTcummins24V 2 posts
bjytech 1 post
I have a Holset WH1C (HX35 essentially) 56/60/14 and am looking at upgrading to a 58mm compressor wheel. Does anyone know what diameter the compressor housing needs to be machined to accept this wheel, before I call BAE? I tried a 60mm wheel and cover previously but it surged so bad I sold it. The WH1C doesn't have the MWE (map width enhancement) slot that the HX has, probably another factor in the surging. I figured for $70 and some machining, a 58mm upgrade would be a good experiment.
Stock 56mm Wheel
http://baeturbosystems.com/compressorwheelformitsubishitd04hl4350mminducer-5600mmexducer-3-1-1-1-1.aspx
58mm Upgrade
http://baeturbosystems.com/compressorwheelformitsubishitd04hl4350mminducer-5600mmexducer-3-1-1-1-1-1-2-1.aspx
