Spdfrk
  1. My truck has 335k on it now. I'm not sure how many miles are on the current ones since I installed them but not enough they should need changing again but I've hit some serious potholes so not sure if that has shortened their life
  2. Sorry if this has been discussed before but I tried searching and nothing came up. I hear the front wheel bearing humming so time to replace them. I've replaced them once already with Detroit Axle units so I'm wondering what brand everyone has had luck with?? '01 2wd abs with drums in the rear. Thanks for any input fellas & have a great weekend
  3. Spdfrk changed their profile photo
  4. Has anyone used a GDP intake or similar(think crazy Larry has a version too)? Heard airflow to the back cylinders wasn't good stock so was thinking about trying to help with that.
  5. Did you ever figure out a solution? I'm fixing to make a 15hr drive to North Dakota pulling a light empty trailer and am looking for a good tow tune.
  6. No check engine light
  7. A little while ago my truck started act funny. You would get on it and then when you would let of it would "fast lope" idle real rough and eventually clear up. Well yesterday I got on it, it started running rough then died and wouldn't start back. I sat in the middle of the road for about 10min trying to start it before I got mad and used the starter with the truck in gear to pull it out of the way. About 20' of that and it fired right up. Any suggestions on what it might be? Only happens after getting on it.
  8. Man I guess it was just some kind of glitch because it just magically worked the next time I stopped and tried it 🤦‍♂️
  9. Drove the truck it's fine, get in it the next day and the settings won't sync to my phone nor will it load a tune that I've used before. Only had it like 3 weeks and already giving me problems 🤬
  10. Well after today I'm off for 4 days so I plan on messing around with it & trying to learn what's going on with it. I just know it's a world of difference. Went from 38psi to 50+psi, egt's will hit 1300°, it'll wrap the speedo pretty quick to 110mph.
  11. Mine will go up to lvl10 so I'm not sure how hot of a tune that is, there's nothing in the manual describing each factory tune that I saw. I know it's a huge difference from the smarty but it runs pretty clean. I wish I could get the speedo video uploaded but it keeps erroring out.
  12. I plan on buying your mileage tune & probably a "race tune" from someone.
  13. Excellent! I don't mind paying for tunes/ppls time but I still wish some of ya were close to talk about this stuff since I'm new to all this downloading, importing, etc. I took my mustang, had it dyno tuned & rolled on lol I could run 8psi to 16psi and not mess with anything.
  14. I'm sure those little 245's don't stand a chance because mine was trying to spin in 4th gear lol So where's the best place to read up on/learn how to tune/maybe get custom tunes that have already been made?? Didn't seem like there was anything real helpful in the instructions but I was only able to skim over them. I'll probably bring the instructions in tomorrow and see if there's any helpful info in there.
  15. So the lvl10 is still somewhat tame? I can't image it pulling harder than it does 😳 I tried to upload a video but no luck
  16. I haven't had any time to really mess with it but mine goes up to lvl10, guessing a pre-programmed tune??
