Everything posted by timsch
Lost coolant - engine got hot
I did fill with the thermostat out. As soon as water came up to thermostat level, I put it back in and attached the hose. Add more until the radiator topped off. If I'd premixed, I'd be too low on concentration because what was already in the block was only water left over from the flush with my garden hose that I couldn't get out.
Total capacity is 6 gallons. It only took 3.5, so I assume there was still 2.5 left in somewhere. I found no block drain plug. Maybe there's air. I'll find out soon enough.
Just refilled it as you described. It took 3 gallons of coolant concentrate and only 1/2 gallon of water before topping the radiator. Surprised I didn't get more water from the flush out. No big deal though. A squirt of WD40 up the drain hole got it moving much more freely. All's good (knock on wood). Hopefully I'll never make such a bad mistake again....
True, but the time it needs to be turned after years and it breaks then it's a problem. I'll get a q-tip and put some of my Parker o-ring lube on it if it's accessible as I think it'll be. Maybe it'll work....
Is there a trick, or is it just a pain? Any risk? I've got plenty of o-rings. That being said, mine's not leaking. I just want it to turn easier. Perhaps getting some lube up into the drain spout would suffice.
Flushed the system per the article here. I'm now emptying the water out from the radiator drain. There's mention elsewhere online about pulling the drain plug on the block, but not in this article, so I guess it's not critical. I couldn't find that block plug. Regarding the radiator drain plug, I couldn't turn it by fingers alone. I made a slot in a 15mm nut and turned it with a ratchet enough to drain. I'd like to pull it all the way out to inspect and replace or lube that o-ring. Is there a stop that could be broken if I force it, or can I safely pull it the rest of the way out?
Thanks for that advice. I'll be removing the thermostat when I do the complete flush this weekend and will do the full fill before putting it back in.
Thanks for the pointers and assurances. i was driving at least 25 minutes before it dawned on me my mistake. It's amazing how efficient these Diesels are to not heat up any quicker than that. Any easy way to check the Check Gages light and chime?
A major short between the ears caused me to lose the majority of my coolant on my drive this morning. I pulled over after seeing mist coming from under the hood. Upper radiator hose was disconnected. My temperature gauge was reading just above the upper line on the sweep but not yet to the red. Engine sounded and performed fine up to me shutting it down. I added about 2 gallons of water back into the radiator and reconnected the hose and finished the trip without issue. Oil on the dipstick didn't look contaminated. I'm hopeful my engine survived my mistake with no ill effects. Is there anything on it that I should check at this point?
HDPE washer fluid reservoir crack repair
The only Rockauto option was out of stock, and searching that PN turned up nothing. Nothing on Geno's, so I concluded that it would be hard to find. Looking again this morning, I found one at Partsgeek for $40. That'll work. i'll probably try to solder weld the original just to work on a skill though. Might need it sometime.
I have a 2" crack in my washer fluid reservoir. Plastic weld repair is the way I'd like to go. I see info online about techniques, but thought I should check here for actual experience welding these since I'm having trouble finding replacement reservoirs and I may only get one shot at the repair. Have any of you successfully repaired a crack on this reservoir? Any tips if so? thanks.
Working through miss/studder issues - codes 0237 & 0230
You and me both. No fun, and I could have easily never seen it. I'm guessing this is the culprit behind the two fuel pumps that the PO had put in. I'm wondering how something like this could be found if it hadn't caught my eye?
In my picture above, the problem was the bottom right, which according to the above, would be pin #7
A few days ago I disconnected the harness connection to the VP44 to clean the silicon based dielectric grease and redo it with Motocraft XG-12, which I read was more appropriate for harness connections. I noticed one of the female connectors was sprung more than the others, and appeared to have some corrosion. I sprayed the connectors with Deoxit D5 and ran a brush for cleaning paint guns that was a good fit through them. I then sharpened a pick to be able to get in and pry the sprung connector back together and pushed some 30ga bare wire down into the slight gap between the OD of that connector and the plastic, which held it in place pretty well. Put it all back together. Two short test drives and one longer one today on the highway, getting on it pretty good, one time floored, and it didn't miss at all. Looks like that connector may well have been it the whole time. Sure hope so.... Before pic:
Yes, that's me giving it the throttle. I can ease it up to speed, but any greater acceleration and it starts cutting or bucking. The more throttle, the more likely it's bucking. And it's consistent now. Thanks for sticking with me John. Edit: One thing I keep going back to in my mind is that the PO said he'd replaced the fuel pump a couple of times. So, a couple of possibilities: either something in my system may killing these pumps, or I'm dealing with a reman pump of not good quality that's failing. I recall reading on the forums that there are recommended rebuilders and you don't want to go cheap on that.
No progress yet. Here's a video showing minor sputtering around 10-13 sec, and then major from 20-25 sec. The shaking is just from the miss. Typical road bumps all other times. Log at the same time showed no red flags at those events. https://drive.google.com/file/d/1E14BZAQJ3RQUKvTiRCBajmeTOiAcBrsw/view?usp=sharing
No apologies needed. I appreciate your help. It's not urgent, as this is not a truck I rely upon now.
Looks like I'm out of luck for now getting a comparison VP44 log. Then I need to do more focused troubleshooting on the electronics between battery and IP. To get better access, I'd like to remove the original fuel filter housing. The PO bypassed it using the FASS, but left it mounted so that the wiring plugs could still be plugged in. Any problem running with these plugs dangling?
I have a good mechanic friend who has a 12V 5.9 - so close, yet so far.... I do have a co-worker with a Gen3 which should be the same IIRC. He'd probably be willing to let me plug in and take a similar log. Thanks for the suggestion. That 1st friend is a pro, so has the good equipment. I'm close to asking him to plug his in and see if the results are the same. My $400 setup may be lacking being consumer grade. The bottom horizontal scale is the number of lines done during the log. Looking at the CSV file (attached)ueoa, a read is done every 180 milliseconds, and with 4 datapoints captured, each line is ~750 milliseconds. When it cuts out, it feels stronger than just one misfiring cylinder. It's a pretty decent stumble, but this is my 1st Cummins (or large diesel even), so I'm not sure what a single cylinder misfire feels like compared to all dropping out. I'd guess more the latter. When I'm driving normally and it stumbles, I ease off to try to get it to stop immediately. Last night, I was powering through them for logging purposes hoping to make a dramatic chart and was a little surprised that it didn't really bog down on me, but rather climbed through them. Dodge-Cummins-2000-December 04 2025.csv
Here is a log I ran tonight. I had several accelerations where it cut out, some multiple times. Every significant acceleration had cutouts. Some patterns here, but not 100% consistency. Battery voltage @ pump has improved, but still has drops; they don't match up with the cutouts though.
No log this morning, so I do not know about the voltages. I do have a pressure gauge in the cab, and it reads a steady 16 psi. One thing I've not looked into is the throttle position sensor (I forget what it's called on the Dodge). I recall people having issues with that, but don't know what the symptoms of that are.
This morning was the 1st test after all of my wiring and termination work. There are a few details to finish up, but nothing that should be that critical. I did disconnect the ECM, sprayed it out with Deoxit 5 and reconnected it. I did not remember to check the wires as suggested in the Man's post on Oct.14th. It was missing worse than ever. Only at heavier acceleration though. Gentle acceleration is fine; cruising is fine; as soon as I need some get up and go when already moving is when it starts cutting out. I can gently get to highway speed, but that's about it. I did not log this time, so have no data to go with this update.
Mr. And Mrs. Michael S. Nelson has occured!
Congrats. All the best to you both.
I got some of the battery cable upgrading done. One part not done was rerouting the power cable from the alternator to the auxiliary battery. Now it goes over to the power distribution center. In my case it connects with one hole only. It has 2 holes and looks like it could mount through both and go to the 140A fuse. Is mine hooked up right? Is this 140A fuse not reliable, which is why I've seen using a 140A breaker rather than just hooking to the aux battery? Another thing - when looking how to get to the ECM plug, I noticed that my OEM fuel filter housing was there with the electrical connections plugged in. Does having those plugs disconnected cause problems? I've seen vids where this housing had been removed.
