Everything posted by Wulf
Tappet cover gasket
How long should it take to change a tappet cover gasket? Cummins says that is where my oil leak is at.
Mopar1973Man's Crankcase Vent Modification
These links are not working for me.
Newbie - Needs help with Startup Issues
Hi I will try and help while you wait on the experts. First the dimming you see that goes away is more than likely the grid heater going on and off, this is normal until engine warms up some.Do you have a volt meter on your instrument panel? What do you show for voltage?Second, if you do not have an engine heater I would be surprised. It is located on the passenger side bumper height just to the left of the radiator if it is still in the stock position. Raise the hood and check it out. You are waiting for the "wait to start light" to go out. Are your battery connections clean and tight?Hope this helpsDavid
checking codes in '01 cummins
Found the pdf file for codes thanks MoparMan, saw in your demo you had same codes displayed. Is this normal?I am thinking of getting the tsb done for high idle, my local dodge dealer has not heard of itsays they can do it though. Should I use them or go else where?I am hoping to find a used smarty that has the tsb stored in it. Thank You for a great resource.David
I have a 2001 I just tried mine I only get one done before going back to odometer,I have codes p0500 and p1693. What are these codes?ThanksDavid
Bio Diesl and 2 cycle oil
Hi,Where I get my fuel the pumps say 5 to 20 percent biodiesel( soy), can I still add 2 cycle oil with no ill effects?Thanks David
Fuel gauge trouble
What is involved using the Scangauge II as a fuel gauge?
Oil pressure Gauge
Where is the sender for the oil pressure gauge located mine reads 40 psi any time the key is in the run position.David
Fuel gauge trouble
My fuel gauge only reads between full and a little over half full.Is this a problem on 2001's, I know on my 96 it was common except itwould not work at all. What can I check out with out dropping tank?Does the overhead display that gives mpg readout use the gauge to compute totals.ThanksDavid
Replacement doors/ bottom panels
Thanks I'll call them after Christmas. I wish you a blessed and happy ChristmasDavid
More 2 cycle oil stories
Thanks,anyone using amsoil 2 cycle oil?
Anyone have a source for replacement doors, the bottom of mine are rusted.Any recalls seems like I see alot of trucks in the same condition as mine.:Mad:2001 3/4 extended cab sport.ThanksDavid
It appears that this thread is dead do you have another link? What oil are you using? Thanks David
