tly02
  1. 3.87 here in honolulu, hi ....aloha.
  2. PROBLEM SOLVED!!!! Thank you all for your help and your advice - so i decided that i couldn't take it anymore - so i dropped my spare tire & started from the back of the truck checking the harness & i found the left rear wire cut because it was rubbing against the rear shock (there was not enough sleeve) Now its working perfect! again thank you all for your help
  3. thank you for your advice - but i'm still trying to figure out what is wrong w/ my lights. i did all the above, and i found out that i have tail, brake, and signal power to the 7 point connector - but, the left signal is still fast. i dropped down the spare tire & i checked the harness for twisted/cut wires, and it checked o.k. I also checked all the connectors & wires w/ the gage in several areas along the rail all the way to the front, and i found that i have power, but still, the left signal is running fast. after all this investigation i think that my problem might be the multi function switch. where is the best place to get a multi function switch? (my dealer asking $150)
  4. - so on the passenger side all is fine front and back!- on the driver side the front is fine but the signal go fast- the problem is the driver back side. i have only the taillight on, but the brake and the signal are not working. even with new bulb.
  5. My driver side rear signal and brake light stopped working - I replaced the bulb, checked the fuses (fuses were fine), and checked the wire harness w/ the gage, and it is still not working. I checked the trailer outlet and there was no power coming to it, either. I'm out of ideas - help would be appreciated! PS - everything is fine w/ the passenger side. :wtf:is going on?
  6. good job man!!! looks very clean
  7. hey guys,I just bought a pair of fog lights trim from LMC TRUCK. but, it came without any hardware!...so do i need rivets or metal screws to connect them to the bumper?...
  8. mopar man what is the serial number inside your center cap?... it is 2124?
  9. [ATTACH]1404[/ATTACH]ok, so i mesured my lugnuts and they are 7/8 from the wheel to the top of the nut...and they are also 7/8 wide... looks like mopar's luguts!!!
  10. mopar do you have any pics of the lugnuts?...my truck came with
  11. I changed my wheels on my 02 from steel to alloy, the center caps from the steel wheel didn't fit!,I got on ebay a new set of caps that were supposed to fit. THEY DONT fit the lug nuts!!! if anyone of you guys run the same wheels please let me know which cap you used. thanks.
  12. Thank's edcasey, that looks easy even for me!!!
  13. can somone please post a diagram for wiring fog lights
  14. That was It !!! Thank you edcasey!!
