David Webb
Everything posted by David Webb
  1. has anyone tested the difference in warm up with 3 cylinder vs normal high idle? will be going back to a quadzilla soon and wondering if I should just order one of these just for the 3 cylinder...
  2. Okay so when I stack it with tst comp. The edge does timing thru the can bus correctly? So without the wire tap on the edge the timing will still get more aggressive as the power levels go up but stay around 65 HP even on level 6 right?
  3. How do you think it would stack with the tst comp? My truck out of all tuners I have ran it seems to love the edges timing the best. Also with an edge juice does anyone know if the timing gets more aggressive through the power levels especially level 6 hot unlock? Or is the timing the same... I found a website last night that stated for the 98 to 02 the edge evo added "95" horsepower over stock.
  4. Any update on this? Would like to see if it is actually at least 80 HP... Might stack it with tst comp...
