Mongoose
  1. So then it's not my alternator correct?
  2. The ac voltage isn't over .028 how do I justify bad alt.
  3. Ok guys I did the apps reset Friday and no issues yet. When I put the new pump in I didn't unhook batteries so I'm not sure if you need to reset apps when a pump is installed but so far so good. If this fixes the issue how long should I wait to re mount the bd stealth cover on the new pump
  4. I did it for giggles today when I came into work I un hooked batteries and did the reset when I left.
  5. Ok awesome. Thank so much. I'll let you know
  6. So wiring is not my thing I'm not completely helpless but I don't love it. Where do I start and what do I look for. I have a power probe , multimeter and test light.
  7. Is there a jumper wire I could put in just incase
  8. Ok will do. I'll report back thank you
  9. I'm cruising down the rpad or accelerating the the truck dies to a idle like I just let off the throttle then picks right back where ever the pedal is. Sometime I will let off and floor it and there's nothing there and then it picks up throttle. Not lack of power or pedal. Just like the pedal isn't there. I haven't tried the fuel cap but I've never heard a suction or vacuum on the tank when I open it. If the vent were the problem would I loose fuel pressure? Because I have no loss in pressure. Is there some way to check the vent?
  10. Does not drop correct Both...if I get in it and go it will do it and if I let it warm up. And it does it under load and cruising. High rpms and low
  11. I'm stumped. I am so confused. I shouldn't have to change filters every 2 months. And I'm running the good cat filter with a Baldwin water seperator
  12. I put a xdp. Sump on it and big line kit
  13. I used the wire harness included with the air dog 165. It cycles with the key. And is controlled with ecm
