Nates1999
  1. Thanks all. Looks like we will take the highlander.
  2. Hey all. I could use some advice regarding snow chains for my 2wd. We are going up to mammoth over Christmas and can either take my truck or my wife's highlander hybrid (also 2wd) which is front wheel drive. Both cars have highway tires, as we live in southern California. We will need to get chains one way or the other and was wondering which you guys think would be the smarter choice,so I can go ahead and order up. My truck is certainly more durable with my ranch hand bumper etc, but the highlander will have its weight over the front drive wheels vs the pickup bed, and it seems that having the chains in front might help a tad with steering and control. Thoughts?
  3. So for someone who lives in Southern California with winter morning temps from 40-55 degrees and pretty short (8 mile) hops to and from work most of the time, is this something that is going to be of significant benefit?
  4. So my truck has always had an intermittent problem with throwing code p1291, especially when its wet out (rare these days in California). PO told me when I bought it that if I ever had the CEL come on it was almost certainly a loose post connection sleeve at the relay (skinny wire press on sleeve) working loose. Ive generally found that to be the case, but im getting tired of it happening and am wanting to fix it for good. Ive already tried to pinch them slightly for better connectivity with limited success. Any issue with clipping them off and replacing with ring terminals to screw down? Anyone know the size off hand?
  5. Thanks. Now i just have to track down a stud. Local Cummins doesn't have it in stock. Hopefully my local NAPA can scare one up.
  6. So.... What should i put on the threads where it screws into the cover? Final count was 1 missing stud w/ nut, 2 missing nuts, 1 hand tight nut holding the pump.
  7. looks like I'm missing the bottom stud too. Red Loctite to screw into the front cover?
  8. Turns out it was the injection pump. Just had a chance to check it out. Doesn't move a whole ton, but enough. Think I need to worry about the gear/keyway or just cinch the pump up to the cover? Thanks
  9. So I noticed yesterday that I had a decent little puddle of oil under my motor yesterday when I went outside. Nothing huge, but more than the nothing I usually see. I'm having a hard time figuring what it might be though. I kind of figured it was the vacuum pump leaking, but I don't see an actual leak from the junction point between the power steering and vacuum pump. It might be coming from further forward. I'm getting most of the leakage down onto my pitman arm, then blowing over my front suspension etc. What I've Noticed: -Oil dripping down the driver's side near the frontish part of the motor, definitely somewhere behind the timing cover. Most drips down onto the pitman arm. -No leaking evident from tappet cover, and I think I can see it pretty good. -Power steering is down a little (between hot and add, when the engine is hot), but that's not surprising, as I know the hydroboost is leaking a tiny bit at the brake pedal, but I suppose it could be power steering fluid. -Oil might be down a hair (maybe half a quart), but it could be just from being on uneven ground. My Question: Is there anything I can do to pinpoint the leak? Anything I should be doing that might make it more evident? Maybe have someone turn the wheel while I'm under there with it running?
  10. unfortunately mine is flush, otherwise it would be a breeze to get something under it
  11. Finally got a good bit of time to spend on this today. REALLY having a hard time. Anyone have any insight. I unbolted the main harness which is the most in the way of everything. This gives me about 4-5 good inches of clearance, but I can't seem to figure out any way to get a screw started. Heck I cant even figure out how to punch a hole in this thing. It's a small plug on the left hand side of the pan between bolts 4 and 5. Kind of like a freeze plug as far as I can tell, but VERY small.
  12. Well. I put on a new cap (again) and new clamps (used constant torque types) and it appears that the issue is gone... Yay! Clamps I was originally sold were way too big for the hoses. They "wormed" down nice and tight, but the new ones are MUCH higher quality. Hopefully all good now.
  13. I just did all this with military clamps and am very happy with the result.
  14. I don't know if anyone is running an enviroguard breather out there, but I just picked one up, and I need to figure out how to get the unused dipstick plug out to install the oil return line. I understand that different plugs were used over the years. Mine appears not to have a lip on it at all, and is just a cylindrical plug pressed in. Any ideas how I should remove it?
