isaac hall
Everything posted by isaac hall
  1. Thanks for the input, I think I need better monitoring and make sure the throttle isn't sending any signal. If the throttle is saying its depressed than I'll at least know where to start.
  2. I do have an OBD reader it can only take snapshots of the engine, and it reads conditions that should trip the high idle. I did think about the clutch switch and simply grounded it, re-calibrated the apps again, no difference. The truck seems to run fine with out doing anything to the ecm although that does not mean I am missing something. I havent heard about the Signal P/N what needs to be done to accomplish this? If the P/N signal is referring to the park neutral signal being sent to the ecm I believe grounding out the transmission is sending the signal of park to the ecm (I disconnected it from the clutch safety switch and grounded it) and the 6cyl still did not function. I have read that there are different apps for auto and manual would this have any impact?
  3. I only did the battery disconnect wait and press the throttle. I did not alter the voltage at all.
  4. My 47re had the shift linkage over tightened (by me) where the post sticks out of the valve body. It made the TV cable very sticky and you could feel it in the throttle. I loosened the shift linkage so it was snug but not binding the inner control post. I tested it by hand to make sure the tv cable moved freely, and problem solved.
  5. I have installed the switch, had the dealer enable the high idle with 3 cyl mode, but the high idle will not function. I had the dealer confirm that they enabled it correctly, and on 6 cyl mode the temp gauge on the dives, so I believe the switch is functioning correcting. Has anyone run into anything similar? I swapped the 47re to an nv4500 this summer and did not replace the apps (did re-calibrate), or ecm, only hooked up the reverse lights and the clutch safety switch (for cruise). The truck runs great, and I would really like this to function any ideas would be much appreciated.
  6. I have the switch now, which is just in time for montana, however I still can not open your link for the installation pdf. Would you be able to email that to me as well?
  7. Do you have any drawings or patterns from the cubby hole pocket from when you offered the plate with the switch? I would like to mount there.
