975speed
Everything posted by 975speed
  1. Idk I didn’t know if it was the pressure relief valve truck runs good in lower gear but higher gears it won’t get out of its own way
  2. Truck starts right up every time
  3. Wouldn’t it smoke white and be making oil if it was injectors I have no cel
  4. As far as I know 222000 the truck isles fine when it’s cold or when the ac is on but when it warms up it lopes
  5. On my 2006 Cummins 6 speed truck is bone stock just straight piped it has a slight lope at idle no white smoke and when driving the truck blows a little bit of black smoke and in higher gears it seems to loose power . I’m thinking it’s the pressure relief valve or the fca but some insight would help. Truck isn’t making oil or losing mpg
  6. Has anyone Experienced a whine from the front of a 5.9 common rail seems to sound like the fan truck is a 06 6 speed
  7. I was making a 4 hour drive in my truck and the brake light and abs light came on truck is a 97 2wd 5speed
  8. When I turn the key I keep blowing engine fuses
  9. My 97 12 valve died pulling into Louisiana last night I’ll be here 10 days can I tie up the solenoid and just stall the truck to kill it?
  10. New tires on rear so maybe u joint
  11. It has vibration anything over 65
  12. It does it only when barely moving could it be a u joint
  13. Anyone have a clicking noise sometimes when stopping or turning truck is a 2wd thinking it could be rear end but not sure
  14. What could I do about more air I don’t have a plate
  15. Would more boost help?
  16. I understand I don’t try and make it smoke just looking for a lil more free power
  17. I haven’t would that make any increase in power
  18. What are some free ways to add power to my 97 12 valve afc housing is slid forward no fuel plate and starwheel turned in a little
  19. What’s the best way to drain coolant on a 2wd 12 valve doesn’t look like a 5 gallon bucket will fit
  20. What is needed to change wheel bearing on a 97 12 valve 2wd and can just the hub assembly be bought with new bearings
  21. Anyone know if the o ring for the fuel screen on a 12 valve is the same on 89-98 trucks
  22. No metal that I’ve seen
  23. What would cause 2nd gear whine from take off trans is a nv4500
  24. Slid my housing forward fixed the problem guys
  25. Alright will rubber hose work
