975speed
Everything posted by 975speed
  1. Ok could a vacuum leak cause my truck to leak oil
  2. What size hose do I need for a vacuum hose my line broke running from pump to firewall
  3. Having issues with my fuel shut off went to pick it up from shop and it wouldn’t start the fuel shut off won’t stay up or even try going up they said there is a security Device by the park brake is black with 2 wires connected to it
  4. Is there a ads relay on a 97 12valve shop said its causing the lights to come on and off
  5. I will all happened after I got my headgasket done
  6. It seems to be on the driver side in that wire group running by the injection pump
  7. Not sure on fuel pressure but ordered a tork tek ofv 300k on factory one
  8. Also a tick in the fuel tank truck has no blow by and doesent use oil
  9. What is causing thi, s passenger battery was unhooked till shop hooked it back up now it’s doing this causing check engine and gen light to come on and tach and speedo to freak out
  10. What’s would cause poor low end performance truck needs quarter throttle to start no smoke or cutting out truck has #0 fuel plate could it be the ofv
  11. Need more power on the low end how do I achieve that fuel plate is out
  12. Has any heard air leak around injection pump it’s intermittent and thermostat housing won’t seal off
  13. How many seals are on a 12 valve injector or o rings
  14. Yea I don’t plan on going big power just mainly stock
  15. Factory head studs and new valve stem seats also
  16. Place priced 1388 for head work new headstuds coolant oil change new gaskets and ac service
  17. What’s a good price for a shop to do my Headgasket
  18. I didn’t know that I just know it doesent really have a hard start but it doesent take a minute to start either
  19. My truck needs a little throttle to start but ik some of these trucks are that way it’ll start without throttle in couple of seconds
  20. Wouldn’t a stuck injector cause hazing out of the exhaust at idle
  21. Previous owner did
  22. Not sure on miles but was told it’s rebuilt
  23. What fluid y’all running on the 5 speeds
