975speed
Everything posted by 975speed
  1. Is there a write up on 12 valve headgasket on here
  2. what does the upper radiator hose staying soft mean
  3. Ok the truck is stock just didn’t know if it was drive able
  4. What would cause head warp
  5. Ok I will is that the rubber flap on radiator cap
  6. Yes leaking coolant but system doesent build pressure or overheat
  7. Head gasket leaking from front passenger corner of head is it safe to drive till next weekend
  8. Anyone have a write up and tools list on changing headgasket on a 12 valve
  9. Could the hose between the head and thermostat be busted causing a leak
  10. Ok cause as soon as I started it this morning I could see a little seepage from either thermostat or head
  11. Wherever it’s leaking from its covered the the front passenger suspension with antifreeze in 30 minutes
  12. Truck was maybe 150 when I got home and no steam
  13. Hard to tell where exactly it’s coming from truck doesn’t over heat or smoke doesn’t have power loss either
  14. I have a 97 12 valve got home from work with coolant all over the a arm and coolant is foamy is it the thermostat housing leaking
  15. How do you change that
  16. What could be causing popping in the steering wheel truck is a 97 2wd 5 speed
  17. Ok just checking transmission doesn’t grind or anything
  18. Bought a 97 12 valve with 292xxx should I be worried about miles drove truck 300 from where I bought it
  19. No shifter just moves a lil on take off
  20. Anyone have a 5speed that moves while moving in gear shifter moves up and down
