2000Ram2500
Quarterly Subscription
Everything posted by 2000Ram2500
  1. Pictures will come later as they are buried in my phone but its really simple. As a disclaimer, use common sense, see what other things i've got done to my truck and take that into consideration before you do this. I am not responsible or liable for anything that happens. For what its worth i am working with a stock truck. No "real" mods or upgrades.. You will need- 1- Eye bolt (with 2 nuts and 1 washer) (i think 1/4 inch is what fits through the old wastegate holes) home depot for less than 5 bucks 1- extension spring from napa part# 7704099 (balkamp) about 2 or 3 dollars 1- 1/8 pipe plug to plug hole in turbo compressor housing left over from factory wastegate air line - oreillys has them but they are pricey at about 5 bucks So i was able to this fairly easily. I learned the hard way that you cannot remove the wastegate with the circlip attaching it to the wastegate lever. First get that stupid circlip off. I used a flat screwdriver with about a 1/4 inch blade and from underneath the truck i pushed up carefully and was actually able to keep that clip on the blade of the screwdriver and not have it go flying down the driveway. You have to reach way up there to get to it. Next take the wastegate off by removing the 2 nuts and its air line. I found this to be rather difficult. My air line was really stuck to the wastegate and fought it for a while. With all the old wastegate parts out of the way you should now plug your old air line port with the 1/8 pipe plug (i actually stripped the fitting and still cannot remove it from my turbo so i have been running with a bolt in the hose with a hose clamp squeezing it in place, verified good up to about 28 psi) This is where i had a really hard time, getting the spring to stay hooked onto the wastegate lever. I tried combinations with washers and ultimately i dont remember what i ended up using as a final solution but when i go to get a finished picture and update the post i guess we will know. But i had a very difficult time with that bit there. The final step is to apply tension to your brand new wastegate. I did not get scientific by any means at all. I havent the faintest idea how much tension is on that spring. All i can say is really well snugged up and stretched out. I did double nut the eye bolt to prevent it from loosening over time with your typical road scenarios ie: vibration/heat. But i took into consideration that it was about a 40lb spring when i did this. Now i will say i have not adjusted mine at all. I put this together back in May and havent really touched it since. I took it for a test run on a freeway onramp near my house and saw my gauge read 29 psi and at that exact moment i lost an intercooler boot. Fortunately i just had about 20 years of oily residue built up and every last one of my boot clamps was LOOSE. Since May I have maintained about 27 psi as a peak at the current spring setting which hasnt changed since i put this together. Reliability seems excellent. Have had zero issues with it aside from the intercooler boot popping off. This includes several trips to Phoenix from the az mountains as well as 2 trips to california. I have yet to really tow with it but i have moved my enclosed across town a few times since then and it hasnt affected it at all. I thought heat would soften it up and lower my boost but no changes even after several hours in the heat (driving across the 10 down to hwy 8 gets hot even at night in august its 100). The wastegate flutters pretty good with a spring on it vs the boost pressure style and your working with drive pressure solely and not boost pressure which changes things. Overall i would say for those in my position (broke, bought a second hand edge that did not come with any of the boost mod parts, needed more air) it is definitely a worth while mod and its cheap and super easy all things considered. I was able to increase my combined average mileage from 12/13 mpg to 17 based on the trucks computer and my commute/driving style (half highway,half city. 5200 ft to 5800 ft elevation). The trucks computer its about 1 mpg over what im actually getting when i do the real math. If you spend more than a day doing this project than your getting distracted or something is wrong. Actual time working was about an hour or two if im being honest. Fit and finish is far below what i would consider professional, clean, bad, etc. Its ugly but functional. Hope this helps (i will tag those who were asking about this)
  2. Just wanted to update this post before its left for dead in the depths of the forum. Not that its really of any importance but were about 2 weeks in and I've yet to see any issues with it finally. Lift pump seems to have done the trick. I was worried about the draw straw that AirDog provides and installing it wrong and I've gotten down to just a hair above the E mark and no hesitation due to air being sucked up or anything even with uphills downhills turns traffic its doing great so far. Thanks to everyone for there input and help along the way
  3. So from the sounds of it i probably dont already have the ability to lock 2nd. I will have to ask a friend of mine who built it then. As far as i know i've got all Transtar internals with a transtar billet triple disc converter and a transgo shift kit (not sure if theres even any other brands of 47re shift kits) Im sure i could ask him and see if he remembers exactly but there a busy shop. He's gonna stab me if i tell him i want to do another lockup switch. He swears thats what killed my transmission but i think its because i had to haul my other friends fully loaded f250 (powerstroke, giant camper, steel trailer, all of his things in his bed plus everything in else in my bed) back across Palomar mtn he was half way to Ocotillo wells when he lost a fuel line and my trans was still bone stock (absolutely no gauges at the time either but at least it was cold out). If memory serves me right, if i had a bone stock trans at the time but with a lockup switch and got cruising at around 20-22 mph (idk rpms) enough to actually shift into 2nd then hit the switch and had it react would that be a rough forced shift to 3rd and not 2-lock. I remember trying to do 2nd gear but its been over a year and a half ago now and i cant remember but i do remember a lower speed jerk into either lockup or the next gear and a check engine light because i did it the way where they say to remove the relay and hotwire the pins with a jumper wire and wire in a switch to ground for the torque converter lockup circuit.
  4. Got the Airdog 150 installed Friday night and taken it across town a couple times this weekend. All seems well so far
  5. @IBMobile I was reading your article on the mystery torque converter lockup switch. Just out of curiosity what mods does the valve body need for 2nd gear lockup. I didnt see it mentioned.
  6. I figured this out the hard way. I used my 4x4 once to make sure it worked and although i didnt need it and i was just out in the dirt it did work. Then a few months later i actually needed it and it wouldnt work. I just assumed it was the switch at the transfer case and it wasnt the issue. The aftermarket world sells the vacuum actuator kit to replace just the diaphragm and thats the route i went for cost saving. In my case the light wasnt coming on at all and once i replace the actuator it would come on again
  7. The governor and sensor are both really common. I wont sell one without the other working here at the dealer because i cant have people coming back in for the same problem and then there pissed about the wasted fluid and the extra work and extra money. Having any codes would be a huge help. If there really isnt any transmission codes it wouldnt hurt to make sure the shift linkage under the body is in good shape. I've never heard of any issues with it but given its a swapped truck its likely to be different from stock or they've used a linkage from another truck or who knows. The throttle valve cable? Isnt there an adjustment on that cable too? I cant remember maybe its only adjusted with the allen screw inside the trans. A quick search on my dealer site doesnt give me any info to any specific cases or service bulletins. Theres the tool on here if you do find a code.
  8. My lift pump went out like a week before your post @Marcus2000monster I finally got one ordered up and it came in friday. Hopefully i'll get it installed this week before the rain/snow is supposed to come back this weekend. Then i can focus on other things and hopefully come up with a parts list and some info
  9. I used to be the same way unless it was my ford and i used the factory trans pan gasket on it. But since i work here and have all the information at my disposal and get a discount it only makes sense. I get factory fuel filters and when my dash fell apart i even ordered the factory cover. Its pretty nice owning a dodge and working here too unlike before and spending 35 bucks for a gasket alone. I will say alot of our prices are totally out of whack. Like the plastic push pins and rivets sell for over 5 bucks each whereas napa sells them for 5 bucks for a ten pack.
  10. I hear you there. Working with the shop at the dodge dealer here I see and hear so many different things changing and this part fits this but not that and all the back and forth then dealing with a catalog thats wrong half the time anyways its hard to keep your facts straight after a while. I keep a data book that i wrote up and put together myself so i dont have to wait for the computer and i know its right. Chrysler doesnt offer that kind of help. The most recently dated cheat sheet is 2011. I could fill this page with complaints lol.
  11. Nope thats how mine is too. Plastic cap its like a 22mm wrench or something to get the cap off and the filter is right there. OE Filter part# 5015581AD fits 2000-2002 according to the manufacturer but if you interchange it im showing it fits 5.9s all the way to 09 according to oreillys parts catalog. 99 and older is the all metal canister i believe.
  12. It was completely rebuilt by a friend at his transmission shop. Billet triple disc converter. Almost everything internal is new. Thats actually was caused the transmission to go out was the torque converter welding itself together.
  13. Honestly its probably all of the above. I know the radiator is packed full of junk from the crank breather. Im sure the fan clutch is original. The water pump is starting to seep a tiny bit. Coolant is old pond water and needs to be replaced. The bigger tires and highway gears is killing me too. I know the trans cooler needs to be upgraded too. Sitting in a drivethru on a hot summer day i have to keep it out of drive or the trans will get too hot. I can start at the menu board and after 10 minutes of waiting to get food the trans temp will go from 160 to 210 but its also got no air flow at that point either but you would imagine with it under no real load that the fan would pull enough air to keep it from burning up in a drive thru.
  14. I've got a big line kit 1/2 inch with a fuel pressure gauge port. My goal was to go with all half inch lines to make the pumps job as easy as possible. Is the inlet on the fuel canister the same thread as the VP? Can I use the fitting airdog provides for the injection pump to attach my supply line to the fuel filter housing. I would use the push lock it has now but its only 3/8 im pretty sure.
  15. Back in August we picked up the rest of my things and trailer from storage because we finally found a storage place here after living here a year. Stopped at the scales and combined we were over 18k lbs. Trailer has 2 quads, a buggy, an old yamaha, spare parts, every tool i own, and the front is converted for camping. Its pretty packed for a 24' enclosed. Anyways Im stock aside from the mods i've got in my signature and at a disadvantage with tires and gearing being what they are. Coming up and over Palomar mtn in southern cali is always a tough grade. Had to pull over and let it cool down before i even got started up the hill. Then driving through the desert it was 110 degrees and we were driving with the windows down and the heater on because the slightest incline would send the temp up if i had the A/C going. Once we got to smooth road that i could really maintain speed on we were able to use the A/C. It was an overnight run so it was dark we didnt leave until 4 pm so it was quite literally 110 at night in the desert. There were some cool spots. Believe it or not 105 feels cool compared to 110 there is a real noticeable difference. Got into AZ and got to the steep grade before Yarnell and It pulled it okay i guess. The coolant and trans temps settled in well above the comfort zone but they stopped going up to i maintained speed at 15 mph the whole way up. If i remember right the coolant was like 235 and the trans was like 240 coming up that hill. Im just going off memory. I'd be curious to know what my EGTs were but i havent had a chance to tap the manifold yet. This was with the edge set to tow mode with the sub level set to 2. I knew it was a heavy trailer and i knew it would be really hard on the truck so i went easy on it. Kept my following distance maintained speed as best i could to try to keep everything smooth. I've yet to see any mechanical issues arise from this thankfully. Just this stupid fass i gotta replace
  16. Been a while but finally got an update on all this. Airdog 150 came in yesterday. Been thinking since I ordered it about how im going to accomplish this. I think the easiest way for me is going to be pulling the bed. I've got a little over 3/4 tank in it now and all i have is a junk floor jack and a dirt spot to work in so for my own sake i dont think dropping the tank is going to work for me. The Airdog came with its own draw straw of sorts and the instructions say that its for trucks that had the in tank pump. This truck has never had the in tank pump but there pickup tube is supposed to be installed into the tank itself and not the fuel 'pump' module so that shouldnt be an issue. I know i will need to plug the openings so i dont get dirt and stuff in there. The return line coming in through the filler neck is a bit interesting to me. I planned on putting an auxiliary tank in the bed one day and i havent been under there yet to see how much rubber line i actually have on the filler neck but i didnt know if anyone else already has an auxiliary tank and got it figured out with the airdog there too. Then my next thing is about bypassing the factory filter. They want you to simply run the line right to the VP from the airdog. I dont have an issue with doing this but i will want my fuel heater and water in fuel sensors given the fact it gets pretty cold here and ice gave me trouble last winter with door locks and headlights being frozen over. Im going to mount the unit inside the frame to keep it protected at least somewhat. Is there an issue with running the airdog into the factory housing? Is the filter the issue will it cause too much restriction? Do i just remove the filter and put the cap back on? I really would rather not have to deal with fuel gelling up on me. Or maybe im just paranoid and it wont be an issue at all
  17. Got it started. Didn't have to crack injector lines but that must've been the issue because it definitely ran like it had a bubble in there. I gave it key starter bumps until the fuel pressure wouldn't go any higher and the most I could get was 13 psi without the truck running at all. After starting it the pressure would drop to 11. If I gave it any throttle over idle it would drop and not recover any pressure. If I shut it off and bumped the starter I could get it to go back up. I did figure out that if you try the key bump to kick the lift pump on after you shut it off from running that it won't activate the lift pump unless you pull the key out and wait about 30 seconds or so before trying again. So it looks like a lift pump will be where I start considering it can't hold pressure.
  18. @dripley Yea i know sorry for the confusion. I havent cracked any injection lines yet so when i get to it i'll give it a whirl. Itll also help me figure out if im even getting fuel in the first place but if i go that route i wont do it for long for fear of making my injection pump worse than it already is. I was meaning i had a hard time getting the gauge line to pressurize and bleed out which to me points to the lift pump being dead or weak. Do lift pumps get intermittent when they start failing? That could explain why it ran terribly the day before i parked it but ran good on my way home that day then ran 10x worse the next morning. I'll be home before long i'll get some better diagnosis done on it hopefully when i get there.
  19. Thats what i was doing to get air out of the fuel pressure gauge isolator. Crack open the bleed screw and let it shoot out of there until the bubble stop. I would turn the key to run, bump start and let the lift pump build pressure while i grabbed my allen wrench and bled it. But after that and i was trying to start it is when i noticed that it wasnt coming on anymore. I'll have to check again tonight and get the multimeter on it to see if i've got power and all that. But i definitely didnt hear it anymore last night.
  20. Little update but not much Fuel pressure gauge came in from vulcan performance. Got a mechanical isspro 0-30. Got it installed, made a huge mess of fuel trying to get it bled. Cycled the key and bumped it to start and let the lift pump run. I noticed it sounded funny while i was doing that to get the air out of the isolator. The best reading i could get was less than 2 psi. It made it to the first tick mark then a little past it. I decided to try running it. No start, no start, no start. Hooked grid heaters back up and cycled those a couple times to get it nice and warm. Still no start. Then as im about to give up for the night it started, ran like s*** for about 5 seconds and died. Couldnt get it restarted. It was at that point that i noticed i didnt hear the lift pump running anymore. Is it normal operation for it to stop running after several attempts at starting? It just seems too weird that it would coincidentally stop working as im trying to diagnose it. I didnt look into it very much it was getting down to freezing and i was cold and dinner was ready so it was a good time to give up for the day
  21. Im not looking for this to be a weekend truck it is my daily driver.. or was until it went down. My thinking isnt really performance gains that im after i just want the truck back on the road and to not break the bank while doing it and if i can get a 029 off a bus for a couple hundred bucks and it works then great. If it doesnt work out then i'll take it as a loss and buy the correct pump and if it last for years to come then great. What im doing here is looking into what would cause it to not work from the beginning and if it will work what problems will i see and so far i cant find anything that says it absolutely wont work and i cant find anything showing that down the road i'll have melted pistons or something bad. Engine internal differences are minimal from what i've been seeing.
  22. Hope everyone had a nice day off Pictures of the 029 pumps look as though they would plug right into the locking connector for the dodge vp. I was suggesting the use of the quadzilla as a way of making up for any performance differences between the two pumps. Im sure they are all built basically the same and have the same pinned connections. And the CM551 ecm obviously has the capability of running the SO or HO pumps. And for the CM550 i would think that they have 2 connections because the ECM is essentially running the entire vehicle as opposed to providing information to the dodge pcm for the dodge side of things. I cant imagine that bosch completely redesigned the 029s simply because they weren't going into a small truck anymore. For costs and all that i would bet they only changed internals to provide a better tune for the higher output engine. As far as internals go i found these threads here- http://www.competitiondiesel.com/forums/showthread.php?t=133306 this is is linked in the first thread but ill put it here anyways http://www.competitiondiesel.com/forums/showthread.php?t=94268&highlight=rv275&page=2
  23. I found this interesting. https://www.turbodieselregister.com/threads/275-hp-vp44-on-my-01.145316/ Seems i wont be the first one to do this which i figured. But at least other people are having success with them. People arent calling them bus vp's or anything like that I can only find information when i search for 275hp VP44
  24. So I've been doing some digging. The bosch number to look for is 470506029. A few websites have it listed as a RV275 motorhome injection pump. Which would be paird with obviously the RV275 injectors. Im sure paired with the ECM from a bus or RV it probably has a very good fuel map for heavy loads which would be good for towing. Now im curious. Using an SO engine, bolting an "RV275 injection pump to it, giving it bigger injectors, and using the quadzilla to dial in your tuning to adjust for built in VP timing advancement differences (im assuming for now that the timing is different anyways), would this be a possible upgrade for people to do. I wouldnt consider the motorhome/bus pumps very common or readily available but they do exist. Could it mean an easier and longer life for a pump that is set up for heavier duty use. And what about the hot rod vps. Theres obviously a way to crank these up from the SO and HO versions and are those just using "RV" parts to do that
  25. I guess i could try it out and see what happens? Whats the worst case scenario? I would imagine it would be something similar to putting a HO pump on an SO
