Everything posted by Zamboni
High EGTs when towing
Not sure where the rest of the posts went here but here is the question. At what point do i need head studs?
So clamping the line off should stop the wastegate from functioning. Correct? So if it is my boost fooler that's fine. Im going to go ahead and order a quadzilla so i have something i can work with. In the meantime i will build me a boost leak tester and make sure i have no leaks. All my couplers and clamps are new so i think they're ok. I will check back in on this thread in a week or so and let you know how it goes. Thanks for all the suggestions.
That's why i clamped the vacuum line on wastegate. I know it's closed tight because i adjusted rod until no looseness then a couple more turns. My injectors are only about 40 horsepower.
I have no coolant temp issues. Maybe 200-210. So i tightened the rod on my wastegate until it had no play then went a little further. Im now getting about 30psi of boost on hard acceleration in stock and with tuner on performance. Better than it was. I also clamped some vice grips on wastegate line and there was no change. Not sure if that will help when towing but it's about 6psi more than before.
I have a quadzilla boost fooler. I had to take the waste gate clevis off my hy for the hx since it didn't have one on it maybe i need to make sure the waste gate is closed all the way. I'll get an adjustable elbow. I thought the one i bought was adjustable but turns out it was an orifice. I don't have head studs. How much boost before they are necessary?
My boost elbow is just a bd orifice elbow, not adjustable. What kind of boost should i expect from this set up. I thought 24ish wasn't bad.
I'll check for leaks and go from there. Will let you know soon. Thanks.
I have a boost fooler installed and an elbow, peaks about 24-25 on acceleration stable around 20 on hard climb. I don't run the tuner towing EGTs are out of control.
I shift out of overdrive as i start to climb which puts me at about 2300ish rpms at 60-65 and just under 1300° i can hold this speed and temp up most freeway grades just seems to high to me. That's without the tuner.
Everything is stock but what i mentioned. Even without a tuner should the EGTs be this high? I was going to get a quadzilla but wasn't sure if it would solve my problem and didn't want to drop $1k for nothing. If this will solve my issue i have no problem doing it.
Im sure this has been asked but I can't find a thread. I have an 01 2wd 7x.008 153°VCO injectors, BHAF, HX35W turbo, banks brake with 4" turbo back exhaust when towing 12k lbs with no tuner my EGTs are pushing 1300° on a long climb but stable. With my superchips tuner it's much higher, too high. I am trying to figure out what i can do to get these down, if not the truck has to go.
