lost cruise, high beams and the p/brake light is on.
I can't seem to figure this one out. I was having trouble with my brake light switch, got that replaced and working. Now i don't have high beams, cruise control, or day time running lights (Canadian). I have replaced the DRL module and have confirmed that my P/brake switch is working properly but can't think of where to go from here. I have followed the wiring schematics and still can't find anything. Any help would be greatly appreciated.
I had no issues before the brake switch. The multifunction switch seems to work as I forgot to mention that I have a sport model with the four lights. When I switch from low beam to high beam the outside two do not light up and the inside two stay on low beam. I'm not sure how to check the clock spring. I did the gauge cluster diagnostics and no codes came back.
Any blown fuses?
maybe a bad ground somewhere under the dash that is common for those items?
just for giggles and you know whats have you tried unplugging the new brake light switch?  Very unlikely, but I always like to try and revert my truck back to last good point and work from there.
