Hi all,
Just picked up a rust free 2000 from Florida. It's a 2500 Laramie SLT. Any good links on power seats? I got the forward-back working but could use the rest of the switches. I have power to the motors but appear to be jammed. This is my 1st power seat vehicle, so I'm ready to learn!
Thanks,
Dave
  • Replies 4
  • Views 1.9k
Look closely at the seat and the screw part. Carefully loosen the screw shaft so it can spin. You might want to help it out with a little lube too. Very common for seat motors to burn up. Matter of fact I've got a old seat frame I save from the dump for repairing the 1996 Dodge power seats some day. I've also got forward and back slide but the tilt is working on one side. I guess I know what my future project is going to be...
Hi Michael, so where the screw shaft goes into the gear housing, those screws, two of them.
So quite a few gen 2's are getting parted out around here, whats the chance of finding a good used unit?
Thanks,
Dave
All I can say is pull them off and bench test them on a battery see if they spin before you leave the yard. But the electric motors or the switch will fail on those typically.
So for right now I have the seat in a position that's going to work for the moment. I'm going to try & switch seat bottoms just so they should wear better!
