NEED TURBO OIL INLET FITTING O RING
 Im reinstalling my turbo and O-Ring on Oil inlet fitting ( one that braided line from oil filter housing connects to  ), is shot.
  does any body know what the size is or is it OEM Specific ..  this is the oil inlet fitting on the center cartridge of the Turbo.
Edited by rburks
It looked like a regular sized O-ring to me when I had that fitting off changing turbos. You should be able to find one that will work just fine at any hardware store.
quickserve doesn't give any dimensions on it but the cummins part number for that O-ring is 3037236
Thanks
