Hundai Accent... mice nest in cabin air filter
Wife let Jiffy Lube check cabin air filter...  charged a rediculous amount for one...  bits of fast food napkin, wool yarn, and a purple plastic toy frog (the topic of discussion at JL) but now she knows where it is.  When she got home, we went out.  She fished through the cowel slots & got a bunch more fluff.  I think the slots in the cowel need better screening but frankly, it's the cowel drains where they are likely getting in.  I don't know where they are but it has to have them.  We've looked from under the hood...  (thankfully it seems to be blocked from the hood hinge area).  In through the wheel well.  In around the engine but pretty darn tight.
Anybody know?
The only idea idea I have is to pour a cup of water into each side of the cowel & see where it runs out.  Pretty rough idea.
Edited by flagmanruss
  • Replies 8
  • Views 3.7k
It's not clear how the cowel comes appart.  I can see a plastic retainer on each side (push rivet) but I don't see how to separate the cover.  They must be separate pieces.  It "must" be there.
Once the cowel cover is open, probably an easy fix.
http://www.hamanual.com/cowl_top_cover_repair_procedures-1202.html
http://www.hyundai-forums.com/genesis-coupe/284193-cabin-air-filter-mice.html
Most of the cowls I've had off are one piece. Typically there is at least a few screws towards the middles long with those plastic push tabs and maybe some metal clips along the bottom edge.
Are you saying the top & bowl of the cowel unit are one piece?  Yeah, I'm confused.  I'm hoping the top (cover) will separate from the bowl.  I don't want to break any of the plastics.
I'm not desirous of opening the cowel box if not necessary but I can't seem to find the drain openings I need to screen from the engine bay.
I understand now. I was just referring to to the top cover as being one piece. It should separate from from the bottom portion you just have to be a little delicate. Some light prying might be necessary to pop out some hidden push clips. I have seen the drain hidden in the fender before.
Thanks.  That's how I thought it should be.  Well hidden!
I'll do more exploring.  She keeps this roller skate in motion pretty much.
More links I found...  but wife's is a 2012, not 08 as pictured
https://www.youtube.com/watch?v=69OwfK11Y5I
The Accent has got a new cabin air filter in now...  She watched & learned...  release glove box so it can drop forward & it's behind a cover behind it.  Need to protect the new filter before it gets mucked up again.
She had Grand-kids today...  can't work on it when it's in motion!
I will try to get some pictures when I get into it.
2012 Hyundai Accent with cowl removed.  Disconnected the washer hose.  The wiper arms came off easily.  There were 4 push fasteners holding the cowl...  one at each end...  & 2 in the gutter near the center of the cowl.  It was hard to see just where the parts separated...  but I started at the ends & opened the seam as I went.  I just had to get a thin pry tool in there...  which wasn't easy.  The end fasteners were blind & broke when I tried to remove them.  The more center ones were expanders & I could reach under the lip but in the end they broke off too.  Like most modern cars, the cowl lays directly on the edge of the windshield glass & is retained with clips...  just slid forward once the fasteners were out.
Once I had it appart, I got the wife to work on her car.  She chose to shop vac the debris from the cowl trough.  I had bought Scotch Brite SS scrubbing pads at Home Depot for $2.39 (3 pack)...  In the cleaning aisle, not with the steel wool.  They are smaller than I remember.   I think the only part that counts is the part in the drain hole but she chose to leave each pad in one piece even though most is in the trough.
The reassembly was uneventful.  The cowl cover clipped onto the windshield edge.  Reconnected the washer hose.  The center pair of fasters, I replaced with 1/4" nuts, lock washers & bolts...  I stuck a magnet to the bolt head & it held the lock washer up for me while started the nuts.  I'm going to pick up push fasteners on Monday for the blind holes at the end.  I should have bought replacement push fasteners before starting...  the holes are a bit over 1/4".
The cowl cover / bowl seam is hidden underneath...  it would have been more clear IF it had been apparent.  Took it slow & didn't break anything besides single use fasteners.
